Overall Heat Transfer Coefficient
#1 T_bag
T_bag
  • 20 posts
Posted 16 April 2024 - 07:49 AM
I am in the process of determining the overall heat transfer for a HC gas system (mostly C1-C4) at around ~720-750 PSIG. I am trying to estimate overall heat transfer coefficient b/w the following utilities.
1. Heating Utility
    a. HP Steam
    b. Hot Oil
2. Cooling Utility
    a. Cooling water
    b. Refrigerant
i. Note :- Someone told me that HP steam & Refrigerant are going to have a same U value, as both are going to have a phase change (Steam from vapor to liquid & Refrigerant from liquid to vapor). bit confused why it would happen ?
ii. I am of the opinion that steam is obviously going to have a higher heat transfer coefficient than Hot oil or cooling water, but my colleague are making me bit confused as they had used higher U values for Hot oil in their past projects and currently I don't have any reference against their values.
Let me know if anyone can suggest estimate U values or some reference based on the Industry experience.
Edited by T_bag, 16 April 2024 - 10:31 AM.
#2 latexman
  • 1,931 posts
Posted 16 April 2024 - 08:11 AM
Perry's has estimated U values based on service and fluid state.  You should find what you need there.
Another reference for estimated U values is Kern's Process Heat Transfer.
#3 breizh
  • 7,059 posts
Posted 16 April 2024 - 10:42 PM
On top of the resources proposed by latexman , consider the document attached.
I don't know who someone is, better to use references in literature.
