Why Superheated Happen In The Crystallisation Process At 60Degc
aspenplus
#1 HSN202906
HSN202906
Posted 08 May 2024 - 02:55 AM
Good Afternoon Everyone
I'm a 3rd year chemical engineering student currently I have a problem in process design for ammonia stripping process I'm using crystallisation to crystallize at this crystallisation process from some papers the operation temperature is at the range of 50-140 degrees Celsius but in my case when I'll try to input the temperature 60degree Celsius the results became superheated does anyone can give me some insight why is this happened
Thank you so much for reading my post
Modify message
  • 7,031 posts
Posted 08 May 2024 - 04:21 AM
Share with us the references and documents mentioned in your post.
A better description of your process is a must with a PFD (at minimum).
#3 latexman
  • 1,922 posts
Posted 08 May 2024 - 08:10 AM
More details = better replies.
It could be simulation, physical property, and/or convergence problems. It could be you made a mistake. It could be a problem within the paper you have.
We need useful information to help.
