Posted 05 September 2024 - 01:14 PM
I'm seeking clarification on whether hydraulic resistance from piping and components (e.g., heat exchanger pressure drop) should be considered as a credit when calculating PSV relief rate for an upstream control valve failing wide open.
My system:
- Battery Limit Pressure: 18 Barg
- Control Valve: Reduces pressure to 1.5 barg
- Line: 10 ft
- Heat exchanger: specific pressure drop
- Packed bed: specific pressure drop
- Manual valves: ~80% open
- Blower (design pressure: 3 barg): PSV location
Should the relief rate account for all component resistances as flow increases, or should it be sized based on 18-3x1.1 pressure differential?
Posted 05 September 2024 - 02:41 PM
Posted 05 September 2024 - 04:35 PM
My system:
- Line: 10 ft
Yes, in general all components resistance would affect the PSV relief rate...
Posted 05 September 2024 - 10:49 PM
The answer is Yes, all pressure losses should be considered.
Consider this handbook to support your work.
Posted 06 September 2024 - 03:29 AM
Yes, one can take credit of the losses in the fittings and equipment.
My two cents:
1) If you are calculating for brownfield project, go ahead and consider these loss
2) If you are calculating for green field, do not consider these losses and do conservative calculations, because a lot of thing change and you might end up in re-doing the calculation at a later date.
Column SizingStarted by Guest_guoyinyanliner_* , Today, 06:57 AM |
In Hysys, For Horizontal Vessel Sizing,Started by Guest_guoyinyanliner_* , 10 Sep 2026 |
Sizing Two-Phase And Three-Phase SeparatorsStarted by Guest_guoyinyanliner_* , 03 Sep 2026 |
Vacuum Total Condenser With Flooded Surface Control During TurndownStarted by Guest_unvecchietto_* , 02 Jul 2026 |
How To Size A Presure Equalization Line For A 10" Pipeline ValveStarted by Guest_Rerrizftt_* , 14 Jul 2026 |
