Pvrvs On External Floating Roofs
efr breathers
#1 Sadaqat97
Sadaqat97
Posted 26 July 2025 - 09:27 AM
Why there is need to install breather valves (Pressure/vacuum relief valves-PVRVs) on external floating roofs on crude tanks?
  • 6,939 posts
Posted 26 July 2025 - 08:56 PM
Did you check with our friend Google?
Key words: PVRv on external floating roof
A lot of information is available.
Using the search engine in this forum:
Pvrv Sizing On External Floating Roof Tank - Tank Blanketing and Venting - Cheresources.com Community
#3 latexman
  • 1,893 posts
Posted 27 July 2025 - 08:46 AM
When pumping into the tank, the floating roof could reach its maximum height (mechanical stops). Then, effectively there is no floating roof and venting is needed to prevent damage. Similar could be said when pumping out of the tank. The floating roof could reach its minimum height (mechanical stops/legs). Then again, effectively there is no floating roof and venting is needed to prevent damage. I know this ignores other safety features, but PVRVs are cheap compared to losing a tank and its contents. Besides, when one is emptying the tank for internal inspection /maintenance the all the liquid will have to be pumped out, right? Venting will be needed after the floating roof comes to rest on its legs.
