Hi!
This is my first post here. I am a student and am working on a university project that involves Simulink Modelling of a pilot scale rig.
This pilot rig consists of a water filled glass walled Jar with an impeller (vertically mounted) in there. Water enters the Jar near the bottom and leaves (overflows) from a point near the top.
Nitrogen is bubbled via a sparger sitting on the botom of the jar to disturbed the already dissolved oxygen (resulting in desorbing the Oxygen out of water body). We have analysers installed that measure the oxygen contents in the water body.
Here, I am looking forward to a correlation between Liquid Mass transfer Coefficient KL and agitation speed. Though its a direct correlation but have no knowledge of exact correlation.
I am stuck here.
Can anyone Help me please.
Thanks.
AHMED
awais_bhatti@hotmail.com
Correlation Btw Agitation Speed & Mass Transfer
Started by uetian98, Jan 08 2007 06:13 AM
Posted 08 January 2007 - 06:13 AM
Posted 10 January 2007 - 03:39 AM
I think you may search some articles on the agitator sizing and design, which will give the correlation formula between the Mass transfer coefficient and agitation speed.
For your question, here I give the following formula for your referrence.
KLa = k1*(P/V)^a *u^b
Here, a--specific surface area of gas / specific volume
P/V--agitator power per unit volume
u --- apparent gas velocity
a, b ---- dimensionless power number
Here, P is the agitator power with the gas bubbling. If no gas bubbling in the jar, the agitator power P0 will be larger than P. Based on my engineering experience, P/P0 locates is about 0.4 or so.
If you calculate P, you can get the agitator speed based on the agitator power number provided by the agitator's suppiliers.
Good luck!
Ming
ming.guo@iff.com
Posted 13 January 2007 - 02:33 PM
let me be more specific,
Unsteady state mass transfer of Bubbling Nitrogen is given by
V(dC0/dt)=FW (C1-C0) - NAV
Here
V.....................Volume
C0.....................Outlet conc. of Oxygen in Water
C1.....................Inlet conc. of Oxygen in Water
FW.....................Volumetric Flow rate of Water
NA.....................Mass Transfer rate (NA = KLA(C0-C*)
KL.....................Liquid Film Mass Transfer Coefficient
A.....................Surface Area of Bubbles / Unit Volume
C*.....................Equilibrium Conc. of Oxygen in Water
Now I will replace NA with KLA etc. Literature says that KL.A can be lumped together to have Volumetric Film Coefficient and that is some function of agitation speed.
Now what is that relationship --- this is the mystery.
Here
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , Today, 05:29 AM |
Mass Balance ErrorStarted by Guest_Mohammad3799_* , 19 Feb 2024 |
Variable Speed Pump CurvesStarted by Guest_panagiotis_* , 27 Jan 2024 |
Operation Of Heat Exchanger Above The Overall Heat Transfer CoefficienStarted by Guest_Papps_* , 13 Jan 2024 |
