Hi everyone,
In a process leading to Paraphenylene-diamide(PPDA), dimethylterephthalate(DMT) is reacted with glycol. the reaction between DMT and glycol at 120 oC produces methanol which we desire to strip off with ammonia flow. Thus, driving the equilibrum to the right for more production of methanol. My problem is to model the dependency of the final conversion on the ammonia flow. There are 2 streams leaving the reactor: the methanol-rich ammonia gas stream and the liquid stream with trace concentration of methanol.
i 'll appreciate also if i can get info about the solubility of methanol in glycol. at 120 oC
Effect Of Auxilliary Gas Flow On Conversion
Started by aluma, Feb 18 2007 09:26 AM
No replies to this topic
Posted 18 February 2007 - 09:26 AM
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
