It seems to me that just you and I are left to continue this topic. Anyway, I still think that the issue is something fundamental and worth of clarification, although it just starts with a Hysys PV Work Term Contribution input value.
Overall, I just wanted to make the following two points clear.
1. The gas expansion (depressuring process) is between isentropic (S=constant, 100% Hysys PV Term Work Contribution) and isenthalpic (H=constant, 0% Hysys PV Term Work Contribution). This is why Point D on my CH4 Miller Chart is impossible because it is not allowed by the Second Law of Thermo (Entropy will not decrease in all the processes) and Point E is impossible because it is not allowed by the First Law of Thermo (Energy will not be created or destroyed).
2. Work by depressured gas was done in the blowdown process although you did not “see” it or collect it.
Now let us concentrate to our example.
A. As indicated in the ideal gas law PV=nRT, P1V1/T1 is equal to P2V2/T2 under the condition same number of moles in the system (n1 = n2). Therefore, both gas left in the vessel and gas released (in your balloon) are in our finial state consideration and they are at same temperature and pressure.
B. T1 = T2 (Point F on the attached chart) is an impossible because is on the right of Point C. I agreed the assumption for simplifying your example.
C. Hysys PV Work Term Contraction is not a measurement of work performed vs. work content. It is a measurement of degree of isentropic approaching.
D. The final state of pressure (100 psia or whatever) is an arbitrary specification. The final state of temperature is NOT independent on the valve/turbine. If the letdown is through turbine (100% isenthalpic), it is equivalent to process that you have a large cold balloon (low temperature, work performed). If the letdown is through valve, it is equivalent to process that you have a same warm balloon (high temperature, no work performed or work out = heat in). Although there is no turbine and balloon, the real life depressuring is close to isentropic (87%-98% as Hysys recommended). If you still challenge work performed, please review and think over my Point 2 above. The only situation is close to an isenthalpic process that all or most friction heat generated through the valve is transferred back to stream and heat the stream up.
At this moment, I like a cup of StarBucks more than the cyberspace success.
Shan
