I need help to convert 100mmscfd production of Gas wellhead to Tone/day .
Note: MW= 22.15
Convert Mmscfd To Tone/day
Started by , Jun 06 2007 02:28 AM
Posted 06 June 2007 - 02:28 AM
Posted 06 June 2007 - 12:48 PM
Sharif:
I make it a point not to do homework for lazy students.
In your case I am assuming that you have never been taught how to build a "railroad" - an old chemical engineering method of doing unit conversions.
Look at the attached document and study the way I have set up the conversion. First I draw a "railroad" - a horizontal line with vertical cross-ties. See how I manipulate the various equalities, representing them as "fractions" that are multiplied and their units are cancelling out and leaving the desired units. It is very simple to learn and to apply. Once you do it successfully, you will never do conversions any other way. It is logical; it is accurate; it can be easily checked; and it works without failure.
Now you do it with the "PPM" thread.
P.S. Spell tonne correctly next time.
Posted 06 June 2007 - 02:46 PM
Hello Sharif,
There's a very handy tool for unit conversion, developed by Harvey (Katmar?). You can download it by right-clicking the link and choosing "save as" option:
http://www.katmarsof...oneer_setup.exe
Posted 06 June 2007 - 07:33 PM
Yes, Harvey's conversion software is top notch but it doesn't help the student learn anything. Before the student can walk, he/she needs to learn to crawl.
I learned the technique Art has demonstrated in his attachment in my first chemical engineering class many, many, many, many years ago and it hasn't failed me yet.
![]() ![]() How To Convert Gas Mixture From Mole% To Mass%Started by Guest_chemtoli_* , 12 Mar 2023 |
Convert Nm3/hr Air To Nm3/hr NitrogenStarted by Guest_princessme_* , 09 Apr 2017 |
![]() How To Convert Kvs-Value For Water To Kvs For Gas?Started by Guest_Falko_* , 12 Jan 2022 |
![]() ![]() How To Convert Mixture Of Gasoline And Gasoil In A Marketable Product?Started by Guest_qasimali_13_* , 23 Nov 2020 |
Convert Aspen Hysys FileStarted by Guest_IreneLUNA_* , 10 Sep 2020 |
