Hi i am a 4th yr chem engg student and am doin a project concerning sodium hydride reactions in a pharmaceutical company..ythe process used for feeding NaH in this plant is very dangerous as it is done manually..can anyone pls suggest an alternative way/equipment so that the risk could be reduced..
Sodium Hydride Charging! Urgent Pls Help!
Started by ravi teja, Jun 27 2007 02:52 AM
Posted 27 June 2007 - 02:52 AM
Posted 27 June 2007 - 03:37 PM
Why do you have to post in 2 forums? Since you just joined, it would be nice if you take time to read the rules.
Posted 27 June 2007 - 11:51 PM
well aluma, i am sorry, i did try to delete the topic in the other community but didnt know how to do it..
anyways can u pls help me regarding the sodium hydride charging problem....i have been asked to modify the charging process of NaH so as to reduce the risks involved..
Posted 28 June 2007 - 01:29 AM
Ravi,
There are various options, but you do not state what are you looking for?
What is the current method of charging NaOH? You can have varities from a FCV to a pressurized pt, etc? I think more details would help us evaluate it.
Good Luck
Good Luck
Posted 28 June 2007 - 01:41 AM
Currently NaH is being charged by dropping NaH polybags into the reactor through the reactor manhole but the process is quite risky as there are chances of it getting into contact with moisture from atmosphere or water.
What i'm looking for is a safer method which won't involve manual charging of NaH..pls help and thanks for the reply.
![]() Basic Chemistry - Dosage Of Sodium HypochloriteStarted by Guest_Dorota86_* , 05 Apr 2025 |
![]() Simulation Of Sodium MethoxideStarted by Guest_Eido_* , 24 Jan 2024 |
Flue Gas Treatment With Sodium BicarbonateStarted by Guest_Estiqaatsi_* , 20 Jan 2022 |
Sodium Hydrosulfide TitrationStarted by Guest_shahabn_* , 16 Apr 2021 |
Sodium Bicarbonate From Sodium Hydroxide - Industrial ScaleStarted by Guest_Antrios_ms_* , 02 Oct 2020 |
