i am a student and is in need of help to design the process for ethelene manufacture by hydration of ethylene. the ethanol vapours produced is absorbed in water in an absorption column, by which unreacted ethylene can be recycled back to reactor.
what is the type of packing, packing arrangement and its nominal size to be used in such an absorption column. also, what should be the tower dia., height , number of trays and feed tray location for maximum absorption to occur?
Ethanol Manufacture
Started by mjp, Jun 30 2007 07:18 PM
Posted 30 June 2007 - 07:18 PM
Posted 13 August 2007 - 01:00 AM
QUOTE (mjp @ Jun 30 2007, 07:18 PM) <{POST_SNAPBACK}>
Dear mjp,
To answer that, we have to know the tempreature and pressure inlet and outlet, the flow rate, and the pressure drop.
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
Chemical Reaction Ethanol And CwfiStarted by Guest_Fuentes487_* , 01 Nov 2022 |
Ethanol Dehydrogenation Aspen Hysys Ver 11 SimulationStarted by Guest_marie_02_* , 16 Jun 2021 |
Acetal/acetaldehyde Removal From Ethanol Via Resin AdsorptionStarted by Guest_logancook09_* , 05 Feb 2021 |
Primary Reformer Tube Manufacturer For Ammonia, Hydrogen And Ethanol PStarted by Guest_Hamidkazi_* , 16 Oct 2020 |
