We have a Light naphtha isomerisation (ISOM) unit. Feed passes through a drier before entering the reactor. This drier has molecular sieves and on top of that 19mm balls are loaded. The direction of feed is from bottom to top.
We have seen this driers dislodging during pressure and flow fluctuations. Also we have seen molecular sieves flowing with the feed.
Has anybody encountered such problems in other units, if yes any remedial actions taken?
Isom Feed Driers
Started by sudheer, Sep 27 2007 01:57 AM
Dynamic Simulation After Feed Flow ReductionStarted by Guest_Kakashi-01_* , 20 Mar 2025 |
Split The Feed Into Two Identical StreamsStarted by Guest_tomr91_* , 16 Mar 2025 |
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
Using Feed Compressor For Start-Up Nitrogen CirculationStarted by Guest_behrouzifar_* , 06 Sep 2024 |
Molten Sulfer Feed ControlStarted by Guest_mahmooddalvi09_* , 11 Jan 2024 |
