We are installing a new centrifugal compressor and the design is ongoing.
A proposal has come to keep the suction shutdown valve open during a Process Shutdown (realted with the compressor) in order to keep the compressor pressurised to the suction pressure, discharge valve will be closed. This will reduce the start-up time. However during an ESD the valve wil be closed and the system will be depressurised.
The suction consisits of a pipeline and slug catcher and therefore will not impact the suction pressure of other compressors fed from a common manifold.
I would like to know reference of any similar design and any possible issue by keeping the suction valve open.
Compressor Process Shutdown
Started by bim, Oct 07 2007 04:48 AM
No replies to this topic
Posted 07 October 2007 - 04:48 AM
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Let Down Vessel In Methanol ProcessStarted by Guest_Manue_* , 21 Mar 2024 |
