The dew of Compressed air usually is concerned by us.
But we only can measure the dew of atmosphere pressure air.
So how the dew of atmosphere pressure air convert to Compressed air's? Are there some graphs or tables or formulas for it?
Thank you in advance.
Calculation Dew Of Compressed Air
Started by daiweisc, Oct 20 2007 10:14 PM
Posted 20 October 2007 - 10:14 PM
Posted 20 October 2007 - 10:54 PM
Dear,
I am uploading here a dewpoint conversion chart.As well I am giving you link where you can find out the frequently asked questions related to compressed air dew point.
http://www.vaisala.com/instruments/knowled..._web_sept05.pdf
And here you will find the moisture content relative to the dew point.Here is the link for that
http://www.mellcon.com/p-dew-point.html
I hope it will help you.
Padmakar Katre
Padmakar Katre
Posted 22 October 2007 - 12:10 AM
Dear reader,
If you encounter problem with first link...try below link.
JoeWong
JoeWong
Posted 22 October 2007 - 12:36 AM
Dear all,
When you use the DEW POINT CONVERSION CHART, please be careful...
I guess Padmakar has downloaded it from
compressed-air-dewpoint
Look at the ATMOSPHERIC line, temperature range
- from 80degC to 130 degC and
- from -100 degC to -50 degC,
looks OK...
However, from -50 degC to 80 degC, they are "out". Probably this is due to "scan-and-match" porblem. This has created some doubt on the accuracy on other lines and reading.
Somehow, you may use it for quick reference.
JoeWong
DEW_POINT_CONVERSION_CHART_problem.doc 143.5KB
115 downloads
Carefully assess information in the web
looks OK...
JoeWong
Posted 22 October 2007 - 05:15 AM
Thank you.
Is there any software that can calculate the dewpoint?
Posted 22 October 2007 - 10:50 AM
Dear Buddy Joe,
Thanks a lot dear. Your have a genius mind no doubt.I have checked this.I am thankful for your suggestion.
Dear Daiweisc,
Already you wanted any graph,formula or theory now you got everything so go for hand calculations and make the required program to avoid the same repetative calculations don't depend so much on the softwares for everything.I hope you will not mind for my this suggestion.
Padmakar Katre
Dear Daiweisc,
Padmakar Katre
Posted 03 March 2009 - 11:30 PM
yes
You can download a freeware calculator from www.phymetrix.com that will perform all of these conversions.
Hope this helps!
Hope this helps!
![]() Heat Loss Calculation From Cylindrical Tan;Started by Guest_rasprocess2026_* , Yesterday, 02:04 AM |
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
