I need to estimate what is going in to my distillation column, I use Pro/II.
I know the molar composition on the top of the column, and here in not a problem.
On the bottom the only thing I have is a distillation curve. I know the boiling points for 5,10, 20... % of the bottom products. The method for it is D86.
Based on this information I need to estimate somehow the feed.
Did anyone have similar problem? Or have an idea how to solve it?
Best regards
Feed Estimation In Distillation (pro/ii)
Started by kasiagaspar, Oct 21 2007 03:37 PM
Posted 21 October 2007 - 03:37 PM
Posted 25 October 2007 - 12:30 PM
QUOTE (kasiagaspar @ Oct 21 2007, 12:37 PM) <{POST_SNAPBACK}>
Best regards
Best regards
Maybe I'm missing something, but you could just add the known composition of the column overhead * its flowrate to the known composition of the column bottoms * its flowrate. If you don't have any sidestreams, this will give flowrate & composition of the feed by material balance.
Doug
Posted 25 October 2007 - 01:45 PM
To determine feed composition you need both product flows and for bottom you missing density.
Milutin
Milutin
Posted 02 November 2007 - 06:26 AM
Is it possible to assume somehow the density of naphtha stream? Or at least some close value?
Posted 04 November 2007 - 12:03 PM
You can assume density, if naphtha is reformer feed, end distillation about 160-170degC, density is around 0.72-0.74 g/cm3, if light naphtha 0.6 to 0.65dg/cm3.
Posted 05 November 2007 - 08:30 AM
Thank you very much...
Seems to be resonable...
As i have no other choice i need to make some assumptions...
Best regards,
kasiagaspar
Best regards,
kasiagaspar
Posted 17 November 2007 - 12:14 AM
Can anybody provide me tutorials for pro-ii.
PLEASE :-)
PLEASE :-)
Distillation Column At Vacuum ConditionsStarted by Guest_FriendlyAlchemist_* , 21 Aug 2026 |
Density Meter For Inline Process Monitoring In A Distillation ColumnStarted by Guest_ProcessAtWork_* , 18 Jun 2026 |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
10.000 M3 Tank Cost EstimationStarted by Guest_stelu85_* , 01 Jan 2026 |
