Hi Friends,
I am studying as MS in chemical engineering.the goal of my project is recovery of caustic form the waste solution of mercaptan removal unit by using the electrodialysis system (kind of membrane system) .please let me know more information about this two type of system:
electrodialysis & mercaptan removal unit.
I will be very thankful to you.
Be happy
Caustic Recovery Of Mercaptan Unit By Using Membrane System
Started by meisameh, Feb 17 2008 06:30 AM
No replies to this topic
Posted 17 February 2008 - 06:30 AM
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Oil Production And Desalting UnitStarted by Guest_Ali4269278331_* , 25 Feb 2024 |
