Pressure Drop
Started by Monica_Staff, Mar 19 2008 01:08 PM
8 replies to this topic
Posted 19 March 2008 - 01:08 PM
Does any body have any idea on how to calculate the pressure drop from a pipe that's 16" in diameter to a branched off pipe 1" in diameter, and finally to another branch of 3/4" diameter?. I cannot use Bernoulli's because my fluid is compressible. The original pressure is approximately 29 psia. Thanks for the help
Posted 20 March 2008 - 03:36 AM
I think that using Bernouli is still possible, but you need to recalculate properties (i.e. density) of your fluid (gas) at new pressure - iterative solution will be in this case:
1. assume new density,
2. calculate pressure,
3. calculate density of your liquid at new pressure and compare with assumed value,
4. assume new value until convegence is achieved...
The question is: how to calculate density at given pressure? There are many thermodynamic relations, the simplest (however not recommended) is ideal gas law, other include compressibiliti factor (z).
Posted 20 March 2008 - 06:14 AM
Completely agree with Andree - I just thought you might find this attachment helpful.
Posted 20 March 2008 - 08:39 AM
Thank you for the answers
Posted 20 March 2008 - 10:08 AM
QUOTE (JEBradley @ Mar 20 2008, 12:14 PM) <{POST_SNAPBACK}>
The attachment seems to be missing...
Posted 20 March 2008 - 11:35 AM
Guido:
Good eye! I had to remove the attachment when I recognized it as a .pdf copy of a section from "Flow of Fluids through Valves, Fittings, and Pipe", Technical Paper No. 410, from Crane where the following is found on the Title page:
"All rights reserved. This publication is fully protected by copyright and nothing that appears in it may be reprinted, either wholly or in part, without special permission."
Unless JE or someone else comes up with Crane's special permission, I'm afraid I can't allow Tech Paper No. 410 to be distibuted through this Forum.
Sorry. But thank you for following through with your comment. This allows me to fully explain the deletion in its full context.
Posted 20 March 2008 - 01:14 PM
I found this Excel spreadsheet long time ago, maybe it originates even from this forum and I remember it was for free. I cross-checked its outputs versus PIPESIM and HYSYS/PipeSYS results, and I found them to be very reliable.
If administrators of Che Forums agree, I will upload it so other members can use it. The authors are from River City Engineering company and I'm using this opportunity to make a some kind of advertisement.
http://www.rivercityeng.com/
http://www.rivercity...-Calc2Phase.pdf
Excel spreadsheet:
http://www.rivercity...P2000-v1.07.xls
Best regards,
Excel spreadsheet:
Best regards,
Posted 20 March 2008 - 01:16 PM
That said, if you don't have Crane, you can still take a look at Art's own excellent workbook in
http://www.cheresour...?showtopic=4936
and follow the links he references in there. Most notably:
http://www.cheresour.../eqlength.shtml
and
http://www.engineeri...ssure_drop.html
and
Posted 20 March 2008 - 01:29 PM
QUOTE (Art Montemayor @ Mar 20 2008, 05:35 PM) <{POST_SNAPBACK}>
Guido:
No problem. I fully understand the reasons...
Of course I have my own (legal) copy of Crane's Paper No. 410 at hand...
For those who don't have it yet, it costs $36 (so that's about 24 Euro's now ) + shipping/handling and can be bought via http://shop.flowoffl...FTechnicalPaper
Design Compressor For 35% H2S & 1.05Ksca Suction PressureStarted by Guest_GanjiS_* , 29 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
