Please help me to calculate the volume of Process tank both in horizontal & Vertical position, with different heads such as spherical, Toro spherical etc.
Process Tank Volume Measurement
Started by Mainak Sarkar, May 20 2008 12:58 AM
Posted 20 May 2008 - 12:58 AM
Posted 20 May 2008 - 06:26 AM
Mainak :
You can use my Excel workbook, "Vessel Volume", which I have distributed for years through these Forums. It will do all that you need plus more.
Use your interest and fingers through the Search feature for these Forums and you will find it: http://www.cheresources.com/invision/index...=1557&st=25
You can download it immediately and start using it.
I hope it helps you out.
Posted 21 May 2008 - 02:13 AM
Thank you sir, but I am not finding your exel programme, also I am asking about the formula for the same.
Posted 21 May 2008 - 06:17 AM
Mainak:
Not only are you reluctant (or too lazy) to scroll down the given thread and read my post, but now you also add that you want the "formula".
Well, when you find the time to download my workbook, you will find that it took a goodly amount of engineering manhours to put it in the condition it is presently in. Addtionally, you will also find that I never employ a "formula" or equation without a reference, an explanation, or a derivation of the same. You will find all of that information in my workbook as well.
I recommend that you also spend some engineering time looking through our Forums for further information - which has been offered and uploaded for free to all who are willing to spend the time and effort looking for what they need.
Posted 21 May 2008 - 10:20 PM
Sorry Sir,
Initially I couldn't down load, so I asked irrelevant question. But now I down loaded the xl sheet. It contains all I want. It is really wonderfully described. I have gone through the whole document. Hopefully you will forgive me!!
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Let Down Vessel In Methanol ProcessStarted by Guest_Manue_* , 21 Mar 2024 |
