any ideas on how to use HYSIS or PRO II to estimate volume of gas (SCF) of a barrel of liquid natural gas (NG) condensate. Composition of natural gas condensate is known for example as given below. NG condensate flows under a pressure of 700 psig and 30 C.
C1=4.6%
C2=14.2%
C3=28.6%
iC4=9.5%
nC4=28.4
iC5=8.2%
nC5=4.5%
C6=1.8%
C7=0%
CO2=0.1%
H2S=0.1%
= 100%
thanks
Babu
Convert Bbl (liq) Of Natural Gas Condensate Into Scf (gas)
Started by BABU, Jun 05 2008 12:52 AM
Posted 05 June 2008 - 12:52 AM
Posted 05 June 2008 - 09:10 AM
This is NOT a matter of simply plugging in the correct conversion factor and off you go. Hysys or ProII are able to use their built-in correlations to estimate standard liquid volumes (barrels) of a liquid hydrocarbon. Essentially, they are estimating the liquid density. There is no connection between the liquid density and the gas phase density. Once you have the gas phase composition (as you have here), you can estimate the SCF knowing that your temperature is 60F (520R) and your pressure is 14.7 psia and your molecular weight is readily calculated by sum of mole fractions * MW of individual components. Then apply V = (m/M * R * T) /P. The resulting V will be in unit of SCF.
Posted 09 June 2008 - 07:31 AM
hysys doesn't have anything special to do the conversions. You can use the same thing they do, the GPSA data book has a listing of the compounds they have compiled from NIST on the conversion of cubic feet of gas per gallon.
Quit using programs to do what you can do by hand.
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , Today, 08:17 AM |
Condensate Storage Tanks In-Breathing And Out-BreathingStarted by Guest_MethanolPlant_* , Today, 08:54 AM |
High Pressure Condensate Recovery To Low Pressure DeaeratorStarted by Guest_hd_1982_* , 16 Feb 2024 |
Rating Of Existing Condensate Fractionator With New Heavy CondensateStarted by Guest_adnanaslam1988_* , 03 Feb 2024 |
Steam Trap & Condensate RecoveryStarted by Guest_salihbaykal_* , 10 Jan 2024 |
