Dear All, being first time here first of all would like to say Hello & thanks every member in this forum who are sharing there valuable thoughts & experience here. I would also like to share my experience & problems here with all you guys so please bear some pain for me.
My concern regarding the problem is that I am not able to calculate the required mixing time in a large tanks for which i have designed a Jet mixing nozzles.
I have searched a lot for proper equations for calculation of blending time but couldn't get through.
For eg we are having a 17000m3 tank storing Hydrocarbon liquid (DHDT Unit feed) with a pump of 275m3/hr for homogenization of stored fluid ( density difference of 30m3 has been assumed)
Can any body help me to find out proper correlations.
I have used one correlation stating blend time as
Blending time = ( Fo *rho * Z) / mu
where Fo = Fourier number = kZ/Re
rho = density of fluid
Z = jet path length = sqrt ( dia2+hight2)
mu = Viscosity of fluid
this gives me a shorter mixing time of around 30 minutes to 1 hr.
Whether I can go ahead with this or not , I am not so confident about .
Any one please help me out. If u require further information just ask I will submit asap.
Rohit
Design Of Jet Mixing Nozzle For Large Tanks
Started by Dev 009, Jul 03 2008 02:49 AM
Posted 03 July 2008 - 02:49 AM
Posted 03 July 2008 - 10:19 AM
Rohit,
I do have a few guidelines from the company standard of a very reputed chemical company.
For a jet mixer consider a minimum jet nozzle velocity of 9 m/s.
The jet mixing time can be calculated from the following equation:
tm = 30*V*Dj / q*(Zl*DT)0.5
where,
V = Volume of the liquid to be jet-mixed, m3
Dj = jet nozzle diameter, m
q = flow rate through the jet, m3/s
Zl = liquid depth in the tank, m
DT = Inside diameter of tank, m
Hope this helps.
Ankur
where,
Hope this helps.
Ankur
Posted 04 July 2008 - 01:25 PM
Dear Rohit,
Further to the above valuable design related info.I will add:
The type of tank (i.e. Floating Roof, Fixed Roof & Fixed Roof with Floating deck/screen) is also critical as sometimes rotations develop in the liquids under mixing and may damage the floating roof or deck in case adequate and strong anti-rotating mechanism is not in-place.
Also, do not forget that this involves <b>eddies generating turbulence phenomena</b> and, as such, the generation of static charges is to be <b>duly taken care off</b>.
Finally, the extent of mixing for large storage storage tank may have to be very carefully/efficiantly designed considering all available incoming steams safe/econmical utilyzation; thus to optimize the <b>Time needed</b>,<b>Mixing affected</b> and <b>Exclusive mixing Needs through special separate higher pressure and/or flowrate pumps</b>.
Hope this helps
Qalander(chem)
Hope this helps
Qalander(chem)
Posted 07 July 2008 - 02:47 PM
Hi everbody , I was reading this information about jet mixers, the equation its very usefull but i couldnt find out the reference (books) (papers) , Qalander, please how could i know where is it? or another source about mixing in tanks, its true the information its very poor on the intenet.
If anyone have an information about this,
Thanks a lot
PD: Sorry about my english
Thanks a lot
Posted 07 July 2008 - 11:05 PM
Dear Ankur Sir,
thanks a lot for sharing such a good information, my doubt is that whether its a empirical equation or a derived equation .
Also having a concern that this doesn't include the density difference factor of fluid to be blended.
With the equation I am getting a reasonable time of mixing of around 4-6 hrs for the various hydrocarbon product ranges.
Rohit
Rohit
Posted 11 July 2008 - 01:19 AM
Dear Rohit,
Sorry for somewhat belated response.Probably you might have already got info from Mr.Ankur
Since this is an information related to another company, you may send your email address and I may give you the specific equation(s) and conceptual info details that might be useful.
Qalander
Qalander
Posted 15 July 2008 - 01:27 PM
Dear Rohit,
Further to today's email to your address and my first reply's <b>possible Static Charges generation / accumulation, if not duly safeguarded through proper bonding/grounding of system components,</b> then possible serious hazardous consequences may result;as depicted in the attached CSB case study. Although (not directly indicating eddies) but <b>turbulence, heterogenous system conditions & not verifiable Bonding/Groundimg conditions are possible contributary factors to create sufficiant energy static discharge in presence of air/ H-C's vapours containing empty space of Tank(s).</b>
All these should be carefully taken care of to avoid similar disastrous possiblities to occur.
Best Regards
Qalander
Best Regards
Qalander
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
