Hi everyone.
I'm trying to reproduce real operations conditions of an Ethylbenze-Styrene packed column Stripper on Aspen Plus.
I've been getting good results, except the ones related to heat duty and steam flow to reboiler.
Actually, the steam mass flow measured is lower than the calculated result. I have good reasons to believe this measured variable is right (instrument calibration, heat balance in condenser, etc). I have already changed the thermodin. package in order to fit the value.
I also increased the theoritical number of stages, but after some steps, no reasonable decreasing in steam flow happened, probably because the minimum reflux is aproaching.
To give an numerical idea, the steam flow measured was 24.1 t/h and the minimum calculated steam flow lied around 25.1 t/h.
What's happening? Would it possible to achieve operation conditions with this simulation?
Thanks in advance.
Styrene Column Simulation -aspen Plus
Started by , Jul 03 2008 11:50 AM
No replies to this topic
Posted 03 July 2008 - 11:50 AM
Ethylene Glycol Purification ColumnStarted by Guest_sg21255_* , 19 May 2026 |
Density Meter For Inline Process Monitoring In A Distillation ColumnStarted by Guest_ProcessAtWork_* , 18 Jun 2026 |
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Simulation Of Natural Gas Water Dew PointStarted by Guest_guoyinyanliner_* , 03 Nov 2025 |
Teg Dehydration Stripping ColumnStarted by Guest_SidRah_* , 08 Sep 2025 |
