hi every one:
We have a separator for natural gas after chiller. The gas go to separator. The height of separator is about 8 feet and OD is about 30 inches. My question is?
Is it OK to shorten the height of separator and increase the OD of the separator. what will be the impact on separation of liquid. will it eliminate liquid from natural gas efficiently.
thank you very much for help.
![](https://secure.gravatar.com/avatar/1d4cca94ac42d3aae5250f6ae949e72a?s=100&d=https%3A%2F%2Fwww.cheresources.com%2Finvision%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Separator
Started by process101, Jul 18 2008 02:52 PM
Posted 18 July 2008 - 02:52 PM
Posted 22 July 2008 - 08:19 AM
Practically speaking, if you shorten the length and increase the diameter, you are, in fact, going to purchase a new separator. (I hope you realize that.) In sizing a new vertical vapor-liquid separator, you typically apply the well known Brown-Sauders equation. Essentially, this gives you a vessel diameter that is sufficient to permit disengagement between the phases. Vertical dimensions tend to be set by a variety of practical (geometric) and process (e.g. residence time) considerations. Increasing a separator's diameter does enhance phase disengagement to a point. (I say that because many demisters rely on inertial impingement for at least some of their effectiveness. This is diminished as the vapor velocity drops.) Vertical dimensions provide adequate spacing for attaining the desired fluid flow paths (even though fully developed flow is not achieved), respect practical construction limitations, and provide enough residence time that effective control is attained. Hope that helps.
Posted 22 July 2008 - 08:47 AM
Thanks allot for explanation.
![]() Flash Drum And SeparatorStarted by Guest_Abdellahi_* , 28 May 2024 |
![]() 3-Phase Horizontal Separator CalculationStarted by Guest_YJ Choong_* , 11 Oct 2018 |
![]() Separator Sizing And Selection, And What Is Slug?Started by Guest_Doneisbetterthenperfect_* , 26 Jan 2024 |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
![]() Modeling Of A Separator (No Liquid Outlet)Started by Guest_niketas_* , 06 Nov 2023 |
