I am using 3A molecular sieves for dehydration of ethanol. By my calculations I have obtained the face area of Bed=2.62 square meters. Using a superficial velocity of 0.5m/s. The bed height obtained by dividing the volume of adsorbent by area of adsorbent comes out as 0.292 meter. From here now how do I calculate length and diameter of the adsorber vessel?
![](https://secure.gravatar.com/avatar/f1b9879b61e658e3e3430e60f85cd1d6?s=100&d=https%3A%2F%2Fwww.cheresources.com%2Finvision%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Adsorber Sizing
Started by David Paul, Jul 21 2008 01:38 PM
Posted 21 July 2008 - 01:38 PM
Posted 22 July 2008 - 08:43 AM
David,
You haven't given us all the details of your preliminary design calculations, but it sounds as if you've done something wrong. For the design a new pressure vessel, I like to "land" with a ratio of length to diameter (L/D) of roughly 3 to 5, unless circumstances suggest otherwise. For an absorber, extra sorbent volume or "wasted" volume are not a problem, except for cost. Remember that you need some vessel height above the bed to promote well distributed fluid flow onto the bed. To discourage maldistribution, you do not want your beds to be too high, and may want to add collectors and (re)distributors to prevent this undesirable phenomenum. Add to this physical and constructability constraints, and I think it unlikely that your vessel would have an L/D below 2 to 2.5.
![]() Pump Dischrge Control Valve SizingStarted by Guest_Lyne_* , 04 Jun 2024 |
Tsv Line SizingStarted by Guest_duongle_* , 28 May 2024 |
Buffer Tank Sizing Upstream Screw CompressorStarted by Guest_Process_1601_* , 09 May 2024 |
![]() Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
