HI EVERYBODY
CAN U GUYS PLS GIVE VERY MANY REASONS WHY NATURAL GAS SHOULD BE DEHYDRATED BEFORE PROPER PROCESSING.THX I APPRECIATE UR EVERLY CONTRIBUTION.
ANENE
Natural Gas
Started by ANENE, Apr 28 2004 03:28 PM
Posted 28 April 2004 - 03:28 PM
Posted 28 April 2004 - 06:57 PM
Anene:
The typical specifications on water content of pipelined natural gas ranges from 1 to 5 pounds per 106 standard cubic feet of gas ... which is equivalent to a range of 20 to 100 ppm by volume. The two primary reasons for removing water from the gas are: (a) to reduce corrosion of the pipeline and (b) to avoid the formation of solid hydrates in the pipeline.
If the raw natural gas is treated to recover natural gas liquids (NGL) such as propane, butane and pentane or higher hydrocarbons, that provides another reason ... to prevent contaminating those products with water.
If the raw natural gas is to be liquified and sold as LNG, the water must be removed because it would freeze into solid ice at the temperatures required for liquifying methane.
Note: In any of your future messages posted here, note that the correct spelling is "you" rather than "u", "please" rather than "plz", "your" rather than "ur" and "thanks" rather than "thx". If you really want to be a professional engineer some day, you must learn to communicate correctly.
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Conversion Of M3 Of Natural Gas To M3 Of LngStarted by Guest_sachico28_* , 30 Sep 2023 |
Increasing Raw Natural Gas Dew PointStarted by Guest_lowrentstuff_* , 18 Sep 2023 |
Purpose Of Natural Gas Saturator?Started by Guest_daraj_* , 06 Aug 2023 |
Natural Gas Wells Location And Production Volume DataStarted by Guest_ChinmoyBasak_* , 08 Feb 2023 |
