How To Size A Thermal Relief Valve
Started by Plumbercs, Sep 18 2008 02:07 AM
31 replies to this topic
Posted 31 March 2010 - 03:52 AM
JoeWong:
It is included in own API 521 5th Edition,not in its Addendum.
#27
Posted 31 March 2010 - 10:43 AM
fallah:
But is is included in the API STD 521 5th Edition, Jan 2007 Addendum May 2008 which is published as a single document where joe is referring to.
#28
Posted 31 March 2010 - 12:03 PM
fallah:
Dear,
You and Joe both may be right in a way that probably the mode of access onto API site could be varying i.e. as a member or free subscriber.
As a free subscriber access could be somewhat restricted as I found early on.
Hope this helps in clarifying the issue& slightly prolonged discussion here above.
Dear,
#29
Posted 01 April 2010 - 02:17 AM
Qalander:
Contrary to your thinking, there is no problem regarding the access to standard and,...., therefore discussion to be done for better clarification...
#30
Posted 01 April 2010 - 02:32 AM
fallah:
OK,
Dear fallah Thanks (I withdraw from my envisaged scenario as you clarify). Whereas I do appreciate your update & still wait for Joe's response;if any!
So that I and other forum colleagues get better/ more accurate awareness on the issue.
OK,
#31
Posted 26 June 2012 - 09:35 AM
Hi Guys,
I am checking if a thermal relief valve is required on the cold side of a new exchanger in case of the blocked-in condition. Isolating block valves are to be installed on the inlet & outlet lines of the cold stream to/from the exchmage. The following are the operating conditions:
Hot Side:
Cold Side:
The design pressures are based on the maximum shut-off pressure of the pumps.
My analysis is that, a thermal relief valve is not necessary because, for the cold-side pressure to reach the design pressure of 1,448 KPag during blocked-in condition, the Recycle Water must attain a temperature of 200 C. Since the Inhibited Water temperature (heating medium) is only 85 C, it is not possible for the Recycle Water to have a temperature of 200 C.
Is my analysis proper? Please comment.
Thanks.
Hot Side:
Fluid: Inhibited Water
Inlet Temperature: 85 C
Outlet Temperature: 33 C
Inlet Pressure: 370 Kpag
Design Pressure: 1,380 Kpag
Cold Side:
Fluid:Recycle Water
Inlet Temperature: 22 C
Outlet Temperature: 79 C
Inlet Pressure: 720 KPag
Design Pressure: 1,448 KPag
Thanks.
#32
Posted 26 June 2012 - 01:55 PM
Pinoycan:
This is an old thread that you are skyjacking. Rather than extend this thread longer than 2 pages, please cut and paste your query into a NEW THREAD on this Forum. Otherwise, this thread get confused and members find it difficult to determine who is answering what and to whom.
I will delete this post after a couple of days, giving you time to start your own new thread.
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
Storage Tank Relief LoadStarted by Guest_hum464_* , 10 Sep 2025 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Minimum Distance Between Blowdown Valve And Cold Vent Outlet In A HighStarted by Guest_AMINEBELAL_* , 15 May 2026 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
