Reading all the posts above I was hoping someone could confirm where you have a centrifugal pump with a minimum recycle the recycle flow will be throttled back to the suction line/vessel pressure, correct? Also, can anyone provide any possible examples of what might cause back flow, and thus the need to design the suction line for the discharge pressure. Thanks.
Dear
Presumably Any accidental closure at discharge pipeline end(s);human error, mechanical malfunction e.g A 'pig' stuck-up blockage in midway or some block valve's gate dropping/stuck etc.
With one of the pump stopped,
other operating and short segment(near the other pump) may be subjected to shock of high back pressure(s)& Non Return Valve's (If provided) are not considered 100% sealing
hope seems logical to you!
I fail to realize the reasons for negative 1 can someone who gave this make me understand!
Edited by Qalander (Chem), 29 March 2010 - 08:00 AM.
