For Piping spec of class Cl 125FF sometimes we take flange & valve ratings as 150# , 300# & sometimes as Cl 125. Which is mandatory requirement & why?
pme
Rating
Started by PME, Nov 12 2008 02:17 AM
Posted 12 November 2008 - 02:17 AM
Posted 12 November 2008 - 06:34 AM
for your specified rating 125FF , flange and valve rating 125 is required for your service . but in some case due to unavailability of material designer used to select higher one according to commercial Availability.
mkhan
mkhan
Posted 13 November 2008 - 12:03 PM
There is never a problem with using materials that EXCEED the design requirements, especially if they are cheaper and/or more readily available.
Sil Rating Requirement For BurnersStarted by Guest_seuenergy_* , 13 Apr 2024 |
Rating Of Existing Condensate Fractionator With New Heavy CondensateStarted by Guest_adnanaslam1988_* , 03 Feb 2024 |
Sieve Tray Rating In Aspen PlusStarted by Guest_Root_* , 24 Sep 2023 |
Exchanger Design And Rating (Edr) In Aspen PlusStarted by Guest_panagiotis_* , 12 Mar 2023 |
Orifice Rating For Hydrogen Gas (Recycle Gas)Started by Guest_engineer24_* , 06 Jan 2023 |
