I have concern with flange-tap to measure differential pressure.
From my company standard, I learn that for liquid metering purpose the flange tap connection is located at bottom and for vapor/gas metering purpose the flange tap connection is at top? both nozzles (for tubing connection) are arranged 45 degrees, so from section view, it looked like V shape.
Questions :
1. What is the reason for bottom and top orientation?
2. why the differential pressure tap connection shall be arranged in V shape?
3. how about measurement for 2 phase flow? let say wet steam, which arrangement we should choose, top? bottom? or may be at side ?
thanks,
