I’m in the process of verifying the line sizes of the fuel gas header/sub header and all the branch lines. These were sized previously by other engineers & I’m doing a final cross check.
The line of concern is one of the branch lines from the fuel gas header. It's a 2" line routed to the 44” Hydrocarbon flare header near the inlet of the flare K.O.D as shown in the attached sketch.
The purpose of this line is to protect against vacuum forming in the flare header.
If the relieving gases are at a high temperature , there is a possibility that this hot gas may be cooled by ambient conditions which subsequently may result in condensation and create partial vacuum (Due to internal contraction) in the flare header. On sensing high temperature the ON/OFF valve will open.
I need the flowrate required to prevent the formation of vacuum, so I can verify the line size (shown as 2 inches). I checked the datasheet for the ON/OFF valve, but since it is a linesize valve the flowrate has not been specified.
Suggestions would be helpful.
Thank You.
