We just installed new flame arrester from Protego. The manufacturer, Protego, on its manual, mentions that basically flame arrester is free of maintenance. It needs replacement only.
We will do what Protego suggests. It is estimated that its lifetime about 5 years.
Depending Upon
1)Service(Paticulates,Filthy/Sticky Entrainments)
2)Environment(Dusty,High Paticulates Soot etc,Birds Shit&wastes)
These are to be replaced;most usually.
Since the very little clearance(s) surfaces deigned to cap /arrest flame(s) can not stay functional after certain period of eposure to such harsh conditions.
This is to be established through regular,rigorous inspections/observations and maintenance.
Hope this helps
Qalander
Thanks Lukman and Qalander for your input.
We typically have a clean solvent service in our tanks with flame arrestors, so it is quite possible that the equipment could last a long time without plugging. Our solvents are compatible with stainless steel, which is what our material of construction is. While it is easy to see if a bird has built a nest within an arrestor, it would not be easy to see down inside without removing it completely from the tank.
Qalander- by inspection do you mean just looking down through the arrestor to see if anything looks corroded, plugged, etc.? Or did you have a more thorough inspection in mind?
Erin
Dear Erin Hello/ Good evening,
It is definitely Pleasant to know that the suggestion was found helpful.I wonder that do you really know the interior construction of a good design flame arrestor?
Since your inspection's narration somehow indicated as if I do not correctly understand construction myself.
I believe in most cases I came across one can not see-through these.Kindly update on this.
Moreover floating Roof's Rim vent's or other flame arrestors are not fuunctional if clogged for any reason;thus could harm the basic service needs satisfaction.
What I implied by rigorous ispection/maintenance and observation was
some especially planned critical and very frequent degree of checking to ensure due functionality and if that is not found upto the requirements
then earliest replacement within minimum time;having replacement ready in stock.
hope this clarifies the issue
Best Regards
Qalander
