I am confused if the yield from an irreversible first order heterogeneous (on the wall) reaction within a given time in a flow-through reactor will increase/decrease with fluid flow rate. It would be great if some one can clarify. The source of my confusion is as follows. On one hand, Sherwood numbers normally increase with fluid flow rate. On the other hand, residence time decrease with flow rate. I am especially interested in very fast irreversible reactions.
Sherwood Number And Residence Time
Started by subhra, Mar 17 2009 08:27 AM
Posted 17 March 2009 - 08:27 AM
Posted 29 March 2009 - 07:51 AM
Subhra:
For a very fast irreversible reaction, you can assume that the surface concentration of reactant (for a rxn A=> on the wall is zero. Therefore, when the flow rate increases, the concentration gradient of reactant near the wall must increase. Then you know, the yield will also increase because the reaction rate is equal to the diffusion rate (from the bulk to the wall).
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Determination Of The Number Of Foam Chambers For Storage TanksStarted by Guest_AnbIran_* , 15 Feb 2024 |
Instrument Air Calculation Based On Strokes Time And Freguency In GasStarted by Guest_keren_* , 04 Oct 2023 |
Inquiry On Calculating Residence Time Of Fluids In SeperatorStarted by Guest_MJA99_* , 07 Oct 2023 |
Bulk Residence Time In Naphtha CrackingStarted by Guest_mehul_* , 19 Oct 2018 |
