I am trying to calculate the capacities of water ring vacuum pump and steam jet ejector connected in series, that will be required to vapourise base oil in a wiped film evaporator. The operating temperature of this evaporator if 330 degrees centigrade, the vacuum required is 0.2 Torr, flow rate of feed is 500 lph, inlet temp of feed if around 260 degees C. The recovery expected is around 90%. Can someone help? Thanks.
Sizing Of Vacuum Pump And Steamjet Ejector
Started by shameer, Apr 20 2009 04:02 AM
No replies to this topic
Posted 20 April 2009 - 04:02 AM
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
