Hi All,
In one of my interviews, I was asked a question for which I could not find a suitable answer yet - even not sure if it was a complete question.
Q: What will happen if a distillation column is simulated by fixing:
a - Top temperature
b - Bottom temperature
c - light and heavy component fraction in top and bottom products respectively
My probable answer was that if the distillation column coverges, it will provide the top and bottom pressures required to meet the fixed variables.
can any one please shed more light on this?
I'm sorry if I was not able to convey my question correctly, will try clarifying any thing someone wants to know.
Distillation Column Simulation With Fixed Temperatures
Started by chemtan, Apr 21 2009 05:58 AM
Posted 21 April 2009 - 05:58 AM
Posted 20 May 2009 - 12:20 PM
this is a rather interesting post... i hope you get the answer you're looking for
simulation rachat de credit
Posted 21 May 2009 - 12:09 AM
QUOTE (katherine04 @ May 20 2009, 01:20 PM) <{POST_SNAPBACK}>
this post is already discussed in detail....
http://www.cheresour...?showtopic=8026
Posted 21 May 2009 - 02:27 AM
QUOTE (chemtan @ Apr 21 2009, 03:58 PM) <{POST_SNAPBACK}>
Hi All,
a - Top temperature
a - Top temperature
I feel above all Reply should include 'H.E.T.P' (i.e.Height Equivalent to Theoretical Plates)
Calculate Mabp,wabp,cabp And Meabp From Distillation Astm D86 ResultsStarted by Guest_barks123_* , 30 Apr 2024 |
Diked Area Around Distillation ColumnStarted by Guest_hysyshunter_* , 15 Apr 2024 |
Distillation Column Decommissioning ChecklistStarted by Guest_m.bhut_* , 08 Apr 2024 |
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
