Hello Everyone,
I am process engineer and working with oil and gas consultant company.For my experience is not much.it's around 1 year for this job.This is my first time for posting.if there are some mistake,please forgive me.
Now I'm sizing vent stack for natural gas metering and regulating station.I so confuse about criteria for sizing.I want to know about Much No. at tip of vent stack used in stack.My boss told me that using 0.99 Much No. for sizing.for this case is choke flow.pressure at tip of vent stack is more than atmosphere and gas velocity equal sonic velocity.if used this case,gas diffusion will be very good.This I misunderstand or not? but I see some work don't used right this.They use Much no less than that.Assumed it's 0.80 . If calculating with value, it's not choke flow so pressure at tip of stack will be atmosphere pressure. This point make me very confuse.this can used or not. In my opinion if there is not pressure difference between tip of stack and surrounding which cause gas velocity.why gas velocity can be 0.80 much No. This make me don't understand for a long time.what point i misunderstand.Please suggest me.
Thanks in advance for every recommends
Best regard,Sakkrit
Vent Stack Sizing
Started by bird_che, Jun 24 2009 04:10 AM
Posted 24 June 2009 - 04:10 AM
Posted 08 July 2009 - 10:45 PM
i've copy this article from http://webwormcpt.blogspot.com
Is PSV tail pipe & lateral at CHOKED (Mach no = 1) Accpetable ?
Above question have been in my mind since many years ago and they have been raised on many occasion. Simple answer to above question is YES & NO.
YES if ...
Mechanical Integrity
Sizing PSV tail pipe, lateral & main header for choked flow is not an issue and it has been done it for many projects. NEVERTHELESS, this kind of design required proper analysis and serious consideration on Flow Induced Vibration (FIV), Acoustical Induced Vibration (AIV), dynamic stress analysis, welding type analysis, selection & implementation, stringent implementation procedures, 100% x-ray test, etc. The PIPING shall be fit for the stress induced by the flow at Mach 1.
Structure Integrity
Several vibration on piping with fluid flow at choked condition may transmit to support structure and potentially lead to structure failure. Again, the structure supporting piping experiencing choked flow shall be properly analyzed and fit.
Tolerable Flow Measurement
Flow meter may be installed on the main header to measure quantity of inventory release to atmosphere. Some flowmeter like ultrasonic flowmeter which is a good choice for flare metering as discussed in Use Ultra-Sonic Flowmeter in FLARE Gas Header for emission monitoring. Severe vibration may lead to inaccurate measurement when it is at choked condition.
Proper Selection of PSV
The product of Mach 1 would be high pressure drop along the line and results high guilt-up backpressure to the PSV. The design shall ensure that the capacity selected PSV will NOT be affected by the high built-up back pressure at the PSV outlet e.g. balanced type PSV. Read more in Several Impacta of Backpressure on Conventional PRV.
Noise Abatement
Another serious issue shall also to be considered is the potential noise level generated by the piping flow in Mach 1 condition. In many event, the noise generated would be higher than the limit impose by local regulatory requirement and company personnel health policy. This would properly lead to requirements of acoustic insulation of piping. As guideline, the noise level limit is about 115 for short term exposure.
A very typically example of above application is the used of SONIC flare tip. Sonic flare tip constructed from PIPE, in single pipe or multiple pipe. It has been designed to create SONIC flow at flare tip in order to gain the proper mixing and elevated flame center.
NO as ...
Stringent requirements and criteria
All above mentioned factors shall be properly analyzed and meeting all stringent criteria
Uncertainties in pressure drop estimation
As PSV discharge could lead to two phase flow (certain part within the collection system), the pressure drop may not be estimated correctly. Those the backpressure at the PSV discharge could be uncertain. This is one of the calculation weakness which is hard to be avoided with present affordable technology and tools.
Conservative Approach
PSV is one of the ultimate protective device within a overpressure protection system. It is normally discharged in to the flare collector. As it is the last line of defense within a safety system, thus it is common that corporate management and company policy imposed extra conservatism in the safety related system.
Thus, in conclusion, a PSV tail pipe, lateral & main header can be designed choked flow condition provided that it is properly analyzed and sufficient design margin has been built in to cater for uncertainties.
i hope it will be useful
YES if ...
Structure Integrity
Noise Abatement
NO as ...
![]() Free Vent For Api 650 Tank - Bug Screen / Bird Screen RequirementStarted by Guest_Cabbarbeybaba_* , 03 Jul 2025 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
