To complete the mass balance I've to know a correlation that tells me which is the liquid volume of a certain gas volume of LGN(C3+) at an certain pressure and temperature. Like, 800 m3 of gas (C3+) will be ??? m3 of it liquefied at 30°C (86°F,303 K ), 100 psi (6 bar, 7kg/cm2, 069MPa) ? The compression volume? Researching at the Internet I've found that the correlation 600:1 of LGN(C3+), but this at normal conditions. Can I apply this correlation to my conditions or I'll have to do the analysis by real gas equations with compressibility factor?
Gas volume (800 m3) -----(refrigeration)-------> liquid volume (??? m3)
greetings
Email me
Compression Volume Of A Gas Phase To The Liquid Phase
Started by coelhothiago, Aug 26 2009 09:19 AM
No replies to this topic
Posted 26 August 2009 - 09:19 AM
Liquid Nitrogen DistributionStarted by Guest_Estiqaatsi_* , 23 Jan 2024 |
Kettle Reboiler Designe Rules - Position Weir, Height Weir, Liquid LevStarted by Guest_Otthigh94_* , 17 Jan 2024 |
Vessel & Tank Liquid InternalStarted by Guest_Danish John Paul_* , 03 Jan 2024 |
Equilibrium Vapor Liquid Solid In Trickle Bed ReactorStarted by Guest_nannanine_* , 14 Dec 2023 |
What Is A Two-Phase Flow For Pressure Relief Device Sizing?Started by Guest_rajbhar_s_* , 28 Nov 2023 |
