We have to design a condenser which is fed with :
- 15.15T/h of steam at T=136.3°C and P=3.13 barA, and
- 17.85T/h of liquid water at T=154°C and P=11 barA.
At the exit the mass flow rate will be 33T/h of condensates at T=110°C and P=10 barA.
Regarding thermodynamic, the problem is clear and I find that after mixing of steam and liquid water at the entry, we obtain a mix of 13,6 T/h of steam and 19,4 T/h of liquid water at P=11 barA and T=184°C (phase change temperature at P=11 barA).
My question is : what is opinion regarding feeding of steam at the entry? Don't you think steam could reflux because of the pressure gradient which is opposite to the steam flow direction?
Do you have experience in this kind of application? and what solution do you preconize to do this mixing (separate mixing zone in the condenser,...)?
Thanks in advance for your help.
Edited by Kaodan, 29 September 2009 - 07:32 AM.
