Naphtha Stabilizer
Started by UWaterlooStudent, Oct 15 2009 01:08 PM
Posted 15 October 2009 - 01:08 PM
What's a Naphtha Stabilizer?
Posted 15 October 2009 - 05:51 PM
A stabilizer is essentially a distillation column intended to remove what is normally a relatively small amount of "light ends" from a product. The product is then "stabilized". Thus one might run the light petroleum fraction known as naphtha through a Naphtha Stabilizer. In doing so, he/she would convert the "wild naphtha" into stabilized naphtha.
Posted 23 October 2009 - 11:08 AM
Dear
Just a very very minor addition to what doug has accurately said above;
the lighter part may also contain slight %ages of LPG like materials and some gases as well if it was"wild" or casing head naphtha.
Posted 06 November 2009 - 11:02 AM
Dear Naphtha material is C5+ so all C5(-) material is taken off and most of the refineries have the configuration of Naphtha stabilzer as a partail condenser with Fuel Gas (upto C2) and LPG as distillate (C3s-C4s) and Bottom as Naphtha (C5+).Dear
Posted 06 November 2009 - 07:38 PM
UWaterlooStudent:
A naphtha stabilizer is essentially a debutanizer, specified and designed to remove most of the butanes and lighter components from the unstabilized (or "wild", or "raw") naphtha.
Stabilizer SimulationStarted by Guest_prashant.badgujar_* , 02 Feb 2024 |
Bulk Residence Time In Naphtha CrackingStarted by Guest_mehul_* , 19 Oct 2018 |
Naphtha PlatformerStarted by Guest_EngrHamza_* , 13 Jul 2023 |
Naphtha Stabilizer Pressure VariationStarted by Guest_mb23_* , 21 Jan 2023 |
Nht Stabilizer Column Control For High Reflux FlowStarted by Guest_Fatema1987_* , 30 Oct 2022 |
