ours is 0.1 mmta / 2000 bpsd straight run refinery with naphtha, sko, hsd, lshs( low sulphur heavy stock) products. crude is of 0.805 specific gravity and diesel production is 110 m3 (max). the sulphur content is 0.024 %wt mass (max). in order to meet euro IV standard for high speed diesel ( < 50 ppm) , please suggest some desulfurization processes which is cost effective. utilities not a constraint
kvkr2882@yahoo.co.in
Suphur Removal From Straight Run Hsd
Started by chetech, Dec 12 2004 09:47 AM
Posted 12 December 2004 - 09:47 AM
Posted 12 December 2004 - 05:39 PM
Chetech:
2,000 barrels per day of crude oil equals about 100,000 metric tons/year ... is that what you meant by 0.1 mmta? That is a very small refinery!
Also, is the diesel production 110 m3 production per day? That is about 690 barrels per day.
Does your refinery include hydrodesulfurization and catalytic reforming of the naphtha? If so, is there sufficient excess hydrogen available to consider hydrodesulfurizing your diesel to the Euro IV standard?
Whether you can use hydrodesulfurization or any other process, it is going to be very, very difficult to be economically viable on such a small scale. In fact, I wonder how a refinery as small as yours manages to stay afloat economically.
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Carbon Filter Used In Hot Benfield Solution For Co2 Removal In AmmoniaStarted by Guest_Abhishek Taware_* , 14 Jul 2023 |
H2S Removal From BiogasStarted by Guest_Aliceat2000_* , 24 Jul 2022 |
Mercury Removal Unit - Aspen HysysStarted by Guest_JJquispedelgado_* , 21 Apr 2022 |
Removal Of Vapor Gases Above The Liquid In Storage TanksStarted by Guest_Aziz-621_* , 09 Jun 2021 |
