We are facing problem in our DC4 column, 'ie' Hydrate formation is happening in air fan cooler; even the condition are enough good and these condition are here,
Column top temp=105^0C
Air fan cooler outlet temp=93^0C (presently all air fan cooler not runing)
Trim cooler outlet temp=39.5^0C
Column pressure=20.0barg
Reflux sample C5+ contents=50%
H2S in boot water 939wt ppm.
high H2S and C5+ contents is the problem, or any one can explain about this problem or have some material for this problem or some one have dealt with problem let me know. we are phasing this problem after unit startup (this unit was under shut down for two month).
Toor
Hydrate Formation In Air Fan Cooler
Started by Root, Jan 05 2010 02:52 PM
Posted 05 January 2010 - 02:52 PM
Posted 06 January 2010 - 01:24 PM
Hi Toor
Something is not clear from your post.. What makes you think that hydrates are formed in the air cooler? Operating conditions certainly do not indicate hydrate formation as likely option.
How did you come up with a conclusion that hydrates are present, what is happening when you keep fin-fans online?
Posted 06 January 2010 - 10:43 PM
Hi Toor
Hi Zauberberg,
We find out the problem yesterday, the problem was with overhead receiver PCV, its PT got freez and indeed there is no hydrate formation.
Thanks a lot for your valuable time to spend on my thread.
Toor
![]() Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
![]() Air-Cooler Heat Exchanger - Unit Vs BayStarted by Guest_pymorty_* , 19 Dec 2023 |
Dry Cooler Vs Cooling TowerStarted by Guest_Quimarah_* , 10 Sep 2023 |
Coke Formation On Hydrotreater Catalyst Vs Ccr In FeedStarted by Guest_Venkat @89_* , 16 Jan 2023 |
Hydrocarbon Emulsion FormationStarted by Guest_CHEMSTRONG_* , 25 Jul 2022 |
