Dear All
In our project, there is a flash drum for separating of the phases of hot condensate suspected of steam traps. feed of this flash drum has 127 degree Celsius and 2.5 bara, and flash drum works in 107.1 degree Celsius and 1.3 bara. outlet temperature of flash drum (107.1 degree Celsius) is too high for us, because this water will be used as feed of polishing unit and as you know the high temperature for polishing units is too risky.
for cooling of this water, our owner suggested to use an internal coil for flash drum which is cooled with product water of polishing water (temperature=52 degree Celsius).
but, is it possible for us to use this water as cooling water and drop the temperature of flash drum under 60 degree Celsius?
the other information, we may need, is:
flow rate of feed water of flash drum: 20m3/hr
diameter and height of flash drum: 1m X 5m
Best Regards
