Dear all,
We have to supply a natural gas flow from pipeline1 to pipeline2. Pipeline1 operates at 80 kg/cm2 & Pipeline2 operates at 72 kg/cm2. Consumption in pipeline2 is 50000 scm/hr.10000 scm/hr is provided from other source. so we have to supply 40000 scm/hr. We think to install a Orifice plate for reducing pressure & supply 40000 scm/hr (or) 550 Cu.M/Hr at 80 kg/cm2 & 35 degC . Orifice plate diameter calculated as 1.475 cm .
Inputs: Q = 550 Cu.M/Hr ; D1 = 18 inch with 15.9 mm thick PL ; Cd = 0.6
1) Kindly check my calculation for orifice diameter 1.475 cm correct or not?
2) Can we just drill a hole(1.475 cm dia) in spectacle blind and use this blind as orifice? Whether this will solve my purpose?
Kindly guide me.
