DearAll,
Posted 09 January 2015 - 09:02 PM
DearAll,
Posted 10 January 2015 - 02:54 AM
Fakhri,
It's not the pump start level nor low low liquid level to keep the required NPSH and pump protection from dry running (if the KOD is equipped with pump); because it hasn't already been considered in calculation of volume available for vapor/liquid disengagement. In fact, it's the volume of the liquid dumps from pressure relief devices from other sources has been retained from prior release and couldn't be removed quickly either by pumping out or by flashing/vaporization...
Posted 10 January 2015 - 07:48 AM
Fallah,
Thanks for your response.
My questions is in which space of a KO drum the 20 to 30 minute emergency relief of liquid (condensed vapor or free liquid) shall be stored? Is that above LSLL, above PSL, above PSH or above LSHH?
Fakhri
Posted 10 January 2015 - 07:56 AM
Fakhri,
In my opinion, between low liquid level and high liquid level. Of course, if there is any accumulation of liquid retained from a prior release, it should be added to condensed vapor plus free liquid...
Answered
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
