please how to size a refinery crude oil desalter? can anyone prvide a document or EXCEL attachment
thank you.
Posted 02 June 2015 - 05:49 AM
thank you.
Posted 02 June 2015 - 09:25 AM
Because of the specialty in the internal design, the info is proprietary and is not allowed to be distributed. You can contact a vendor to get a preliminary idea. Other than the internals the sizing depends on how dilute you are going to need the oil in PTB and how salty the feed is. Mixing efficiency also plays a very key role in the sizing..
If you share your inputs I can do a quick run for you..
Posted 03 June 2015 - 03:42 AM
Mr Ahmadikh,
these are our inputs.
thank you,
crude oil:
-density (g/cm3): 0,8112
-input salt content (ppm): 216
-output salt content (ppm): 8,61
-volemtric flow rate (m3/h): 451,47
wash water:
-percentage of water wash (% vol): 2,85
-amount of emulsifier( ppm): 0
desalter:
-pressure (bar): 20
-Temperature (°C): 80
khaled.
Edited by mhamdi khaled, 03 June 2015 - 03:45 AM.
Posted 03 June 2015 - 10:03 AM
what is the BS&W of the crude (water content of the feed)? and what is the required BS&W in the outlet?
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , Yesterday, 12:03 PM |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
