Max Tank Vapor Flow Rate
Posted 30 March 2016 - 05:30 AM
The following are some conditions:
1. The tank operates at atmosphere
2. The chemical will be unloaded from a truck via a pump-A to this tank. And a pump-B is installed to pump out the chemical to a reactor.
Thank you in advance!
Posted 30 March 2016 - 07:00 AM
Try using API 2000 to specify the total out-breathing flow rate as maximum outgoing flow rate toward the scrubber. For estimation of vapor concentration you need to know, at least, the liquid boiling point at tank's design pressure...
Posted 30 March 2016 - 07:43 AM
To support your work ,
Posted 30 March 2016 - 08:20 AM
Dear fallah and breizh,
Thank you very much for your fast reply and information. I got some ideas to calculate the flow rate. Could you please advise more about the vapor concentration?
How do I calculate the concentration if I know the boiling point at the design pressure?
I am planning to calculate it in the following way, but not very sure if it is correct:
1. Get the chemical vapor pressure @ 80 degC
2. Then I can calculate the molar fraction of chemical vapor and nitrogen respectively (since the tank operates at atmospheric pressure).
Please correct me if the above steps are wrong.
Thank you in advance.
Posted 30 March 2016 - 10:46 AM
If it's supposed the Dalton Law is applicable to the case, the way you described can be terminated to a good estimation...
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , 30 Apr 2024 |
How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Acumulador De Vapor En Una Planta TextilStarted by Guest_Valeriacortez11_* , 15 Apr 2024 |
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
