HI Every One:
I need to find the Design Temperature and Pressure for Upstream and Downstream pipe? I was told that whatever the design Temperature and pressure of the Equipment or vessel is, the design temperature and pressure of the downstream pipe will be same.
Example: If the Design Temperature and Pressure of filter is 200 F and 1200 psig, the design temperature and pressure of down stream will be 200 F and 1200 psig respectively.
Is that Correct? If not can any one please help me.
Thank you very much for your valuable comments.
Upstream Pipe
Started by process101, Sep 17 2008 08:20 AM
Posted 17 September 2008 - 08:20 AM
Posted 17 September 2008 - 05:36 PM
process,
The blanket statement you make is an overly conservative approach. Quick "recipes" that try to eliminate the need for thinking often produce unsatisfactory results.
You should look at the peice of equipment being referenced. Sometimes, there is a pressure and/or temperature increase in moving between the inlet and outlet sides of the equipment; e.g. pumps, compressors, etc. Othertimes there is a pressure and/or temperature decrease. In all cases, there is no substitute to understanding what combinations of pressure and temperature will exist for your various scenarios, including worst case(s). It is the extremes that will determine the design conditions, and the extremes of the piping may differ from the extremes of the equipment.
Age Impact On Pipe RoughnessStarted by Guest_Noman97_* , Today, 04:14 AM |
Higher Pipe Line Dia Specification In UnisimStarted by Guest_Praveen Perumandla_* , 27 Feb 2024 |
Sizing Of Cooling Water Pipe LineStarted by Guest_Asif Azeez_* , 08 Jan 2021 |
Gas In Pipe SupportStarted by Guest_Stellaandoor_* , 26 Jan 2024 |
Pressure Control Valve Relief To Flare Upstream Block ValveStarted by Guest_Glauco_Tirollo_* , 07 Dec 2023 |
