Edited by kepin sheth, 20 March 2010 - 01:39 AM.
Refrigeration System
Started by , Mar 10 2010 10:49 PM
Posted 10 March 2010 - 10:49 PM
Can i know what should be the optimum Cop for any refrigeration system.
Posted 14 March 2010 - 03:44 PM
Kepin:
- Tell us what you specifically mean by "optimum".
- Also tell us what you mean by "any refrigeratio system".
"The coefficient of performance is the ratio of the heat removed at the colder temperature to the work required to do it. Like many other figures of merit (the efficiency of an engine, the miles per gallon your car gets, ) the coefficient of performance measures the ratio of what you get (heat moved out of the box) to what you have to pay for (work from the electric company). But unlike the efficiency of an engine, the number can be greater than one. Because the temperature difference is small compared to the absolute temperature of the box, the energy expended to run the refrigerator is less than the energy moved from the inside to the outside."
If what you are trying to ask us is related to a mechanical refrigeration system, then go to the following website for an excellent example of how the COP varies with the enthalpy values of the working refrigerant.
http://demonstration...tOfPerformance/
Posted 20 March 2010 - 01:42 AM
Hello
OPtimum means acceptable Cop of refrigeration system, for industury
Posted 20 March 2010 - 03:18 AM
It depends on the Refrigeration Cycle Type:
-Carnot cycle has the highest COP (5-6)
-Vapor-compression process with a reversible expansion engine has a little bit lower COP (5-5.5)
-Ordinary vapor-compression cycle (with expansion valve) has lower COP than above two types (4-5)
-And finally,an air cycle has lowest COP (2-2.5)
*Numbers are typical values.
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Using Different Types Of Prvs To Protect The Same SystemStarted by Guest_FarrahC_* , 09 Dec 2024 |
