Dear All !
Can any one guide me where(in boundary) the pressure specification is used in HYSYS?
Does it differ to use pressure spec or flow spec in dynamic mode in HYSYS?
Pressure Spec Or Flow Spec
Started by husubala, Mar 12 2010 11:56 AM
Posted 12 March 2010 - 11:56 AM
Posted 12 March 2010 - 12:10 PM
In Dynamics mode, pressure is specified only for boundary streams (flowsheet inlet and outlet streams). Refer to attached example and try to walk through it using HYSYS. I believe everything will be more clear to you.
Not clear about your second question. Are you speaking about any particular controllers?
Design Compressor For 35% H2S & 1.05Ksca Suction PressureStarted by Guest_GanjiS_* , 29 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
