I'm glad that i just joined your community!
I'm really looking forward to help and to get helped.
Well, this is my first question...
I am a student in chemical engineering and i have to make a feasibility study on an ethylene oxide production plant. The method we use is the direct oxidation process which involves a reaction of ethylene with air on a silver/alumina catalyst. I have a problem with the reactor sizing and i really can't find any solution. The data that were given/calculated to/by me are: the volumetric flow (Q=8,44 m/s), the LMTD (LMTD=79,4), the porosity (ε=0,4), the heat exchange surface (A=2168,9), the overall heat transfer coefficient (U=176 J/(s x m^2 x K) ) the residence time (tr=6 sec), the selectivity (S=6) and the %conversion of ethylene (=20%). I have to calculate the number of the tubes, the tube and the shell diameter and the catalyst and the reactor's volume.
Well, the first thing i thought was to calculate the reactor's volume from the equation Vr (reactor's volume) = tr (residence time) x Q (volumetric flow). Is that correct?
I also tried to assume a tube diameter (d) and a tube length (L) and find the tube number from the equation: A= Ν x pi x d x L
Right after that, i can calculate the tube volume (where the reaction mix is) through the equation: V=N x pi x L x(d^2)/4
But then, i must find the shell diameter and i don't know how. I know that i have to choose a tube layout (for example triangular or square) but what shall i then do?
ps. I just forgot to mention that i have a PFR reactor but the kinetics are unknown and i can't use the PFR's design equation.
Well thanks in advance. I'm looking forward to your replies
