Fitting factor (which takes care of elbows , bends etc) for tubulent flow are readily available. How to get fitting factors when dealing with laminar flow , such as pumping high viscous liquids. I am of the opinion fitting factors in laminar flow will be higher than turbulent flows.
Fitting Factor For Laminar Flow
Started by ayan_dg, Mar 22 2010 01:27 AM
Posted 22 March 2010 - 01:27 AM
Posted 22 March 2010 - 03:53 AM
The standard methods for calculating resistance factor values for laminar flow (and also for turbulent flow) at the 2-K (Hooper) and 3-K (Darby) Methods. You will find a thread on this board that discusses this and presents some useful spreadsheets. See
http://www.cheresour...-pipe-fittings/
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Firewater Theoretical Vs Actual FlowStarted by Guest_stu_* , 25 Feb 2024 |
