Hi All
thank you very much for your cooperation.
methanol steam reformer catalyst was replaced with new one and during plant start up, CH4 slip from the steam reformer is very high. above 10 % while is shall be with 3%.
there is no sulfur passed to the reformer, reformer temp is ok, steam to carbon is ok, catalyst still new, CH4 analyzer is ok.
but still I cannot find the root cause?
Appreciate your full support, recommendation, & provide me any technical documents .
Thanks to all.
Ch4 Slip
Started by thabet, Jul 22 2010 08:59 AM
Posted 22 July 2010 - 08:59 AM
Posted 24 August 2010 - 11:36 PM
check your online methane analyser it is possible while during plant startup while introducing steam to the reformer if u have not isolated the analyser some moisture may go inside and showing a false reading
Posted 31 August 2010 - 01:20 AM
Please check your condition of plant,see my table and report me,y will be calculate agayn.
Maybe if you have "baypass" tube? y dont know.
CH4 slip.doc 142KB
30 downloads
CH4 slip.doc 142KB
30 downloads
Need Help In Calculating Ammonia Slip In Scr Unit.Started by Guest_Redbull010203_* , 11 Mar 2024 |
Design Of Slip Stream For Cdu Overhead Ph AnalyzerStarted by Guest_vjmromero_* , 29 Jul 2017 |
Slip Stream DefinitionStarted by Guest_DANA-IF_* , 26 Feb 2014 |
Slip Stream Filter And PsvStarted by Guest_kybele39_* , 03 Sep 2013 |
Natural Gas-steam Reforming (methane Slip)Started by Guest_Srikrishna Chaitanya_* , 26 Mar 2009 |
