Hi DB Shah & Mr Art
i apologize as i did not provide accurate information for my problem, i work with design company & my design based on our client requirement.
below are information regarding the unit;
STHE type = BEM, i tube pass, 880 mm x 3505 mm
Shell = liquid
Tube = gas
gas MW = 19
inlet pressure = 1004 psia
Calculated HT area (HTRI) = 141.684 m2
pitch = 1.25 with 25.4 mm tube OD, A-179
(pitch, tube OD, & tube length is client requirement based on petronas standard)
my concern is i have to install 6x12" nozzle at the channel side, both at inlet & outlet to cater the tube side nozzle velocity, which is in gas phase (my apology again). as i refer to Ludwig chart for nozzle velocity, it should be below 42 ft/s. in order to meet the required velocity, i have to install 6x12" nozzle for each inlet & outlet channel side.
is there any other way i can do to decrease the no of tube side nozzle, instead of using bigger nozzle? Thanks for your help.
& for Mr Art, as from my understanding, bonnet is the channel head. nozzle will be installed at the channel pipe & about 75 mm from the nozzle, the channel head (which is bonnet) will be welded.
Edited by fatimah, 06 January 2011 - 09:29 PM.
